Is it a bug that Intensity Palettes do not store values for Intens 1 Intens 2, etc.
If you need to store values for a fixture that has a background intensity and a main intensity it would make sense if it did.
Thank you for your report. But I'm not seeing this:
This is a custom fixture, I set manual values in Live and then recorded to Intensity Palette 1.
What fixture did you try, which syntax did you use and what's your Eos version?
It did not record at first, then I edited the intensity palette manually, then it would not recall the data from the palette. After I restarted the software, it seems back to normal. So partly ignore my post. I will report when it occurs again.
