I was just poking around the Fixture Library Hub and on the landing page it says the current fixture library available is 3.2.10.1 however on the ETC downloads page the most recent fixture library available is 3.2.9 b17.
Thanks, Will
Thanks, Will
I can see that as well, will try to find out.
If you're just looking for a place to download 3.2.10.1 you can get it from the FLH, but I'll try to figure out, why the two versions are different.
Usually the library update gets posted in both places, FLH a bit before the downloads page. In this case an error happened, it'll get fixed as soon as the next update becomes available.
Thank you.
