Bump Button doesn't act like a Flash Button
Hello,
I'm gonna try to explain my problem.
When i press BUMP button and Hold to do a  flash and then I want to keep this at full I raise the fader at 100 % and I release the BUMP button. that's work !
After a while I want to turn off this sub Cut, so I press again the BUMP and Hold to keep the sub at Full  and then go down the fader at 0 (with still the bump pressed) but the sub doesn't stay at 100%.
The only solution is to put the fader at 99% so like that when I press the bump and hold I can turn off the fader and it stay at Full untill a release the Button.
On every other desk i know, a flash button has the priority; Why not on eos desk  ?
I do a lot of manual things and it's not possible on eos desk, that's sad.
thanks
