Help! I'm not sure what I have done, so I am not sure how to fix it.
If I lower my GM to zero, every thing works fine, but when I try to bring it up again, it is on a slow timed fade back up! Where do I go to reset the GM to full manual operation?
This sounds like it could be a hardware problem - it will be worth checking in the shell under Settings > Diagnostics > Facepanel test.
Give a call to support if you get stuck: +1 800 688 4116.
-luke-
Upon more detailed examination (i.e. not in the middle of a show), it would appear that it is a hardware issue.
