As shared on FB group, I have the same issue on both M1 MBP and M4 mac mini
Also having similar issues since updating to OSX Sequoia 15.3.2 with Nomad v3.2.8. Uninstall and reinstall to v3.2.10 didn't help.
Symptoms:
- no sACN or ARTNet output
- sACN Output Viewer does not show any entries under Universe sACN Sources
This had been working well until the latest update. I've fired up an older laptop on OSX 15.2.0 and Nomad is working fine using the same show file (shows sACN output and the laptop appears un the Universe sACN Sources list).
Will watch the progress on this issue closely.
From ETC Tech support which fixed my similar issue:
I have seen something similar to this with MacBooks and MacOS v15.7 due to security settings. On Mac there are many settings that get revealed on initial boot of software that if the wrong item is selected it can cause issues.
As a first step I would recommend going into System Settings -> Privacy & Security -> Local Network and make sure that both Eos and Capture are enabled here.
What I discovered is that in those settings, EOS Family was activated, but EOS Family Welcome Screen was not, which indeed prevented the mac wifi to send out the sACN signal. Issue resolved.
Hope this helps someone else.
Sequoia 15.6 & 15.7
Nomad 3.3.1
