I am running version 1.9 on Windows 7 and would like to change the location of the 'show archive'. I know it can be done from the logon screen on the console but I don't get that screen on the offline editor.
Many Thanks
ian
Many Thanks
ian
Can I assume you want easier access from the Windows environment ?. In my experience, I found the off-line editor wants to see the show archive where it is.You can move it, but the OLE is a pain to use to navigate thru the Windows structure each and every time you want to access that file.
I found it easier to create a shortcut to the show archive folder, placing it in a Library folder on my desktop with assorted other lighting data, thus it's readliy accessable
Hope this helps.
Steve B.
Thanks for the reply but, embarrassingly, it turns out I was using the wrong software (I had downloaded and run the client software) hence no logon screen,
I am now running the offline version and get access to the shell settings and have been able to move the 'show folder' and enable to iphone remote.
Cheers
Ian
