Ion Cue List Issue
I have a problem.  I want to be able to have a cue active and also be able to adjust some of the levels using sub master.  I can't because the channels I want to change are captured/owned by the cue.  Any advice how to get around this?  Also, I want to have a cue that is the last cue in the list and I want it to release all the channels it has captured.
  • I am not at the console so cannot test this but you can try [Recall from][Sub]X[At] then nudge the intensity wheel or use [Sneak] to pull them in to the cue.
  • Just a suggestion.
    what is the result you are looking for rather then focusing on how you want to do something.
    You can set submasters to either LTP or HTP depending on how you want them to treat intensities.  You might be able to get the result you want by setting the sub as an LTP sub.
    Instead of a cue list releasing control of channels why not have something else (cue/sub) take control of the channels you want to change at the end of the cuelist.
    Again if I knew what you were trying to do I might have some other suggestions as well.  The Ion/Eos has a great many ways to reach any goal.
