Moving Light Effects in Submasters.
Hello
I have a question about effects in submasters to moving lights, when I using the submaster to make effect of convencional lamps I use the Effectsub mode, I up the Sub and press the bump to start the effect, OK, but what is the best way to record a effect with moving light in a Sub? I tried the same mode of conventionals lamps but I lost the intensity of Movings chanels in this SUB, this is normal?
Thanks.
