New fixture profile does not show gobos
I am trying to write a fixture profile for a fixture which has three bulbs, and a gobo wheel for each bulb. There is one intensity channel for all three bulbs, the same rgb channels control all three bulbs, but the gobo wheels are independent.
I've defined this as a multicell fixture with intensity and rgb channels in the master, and three cells with a gobo select channel each. I can set intensity and colour, but the gobos do not show up in the encoder or ml controls in etc nomad. Is this the correct way to define this fixture? What do I need to do for the gobos to show in ml controls?
  • Did you add ranges to your Gobo_Select parameter?
  • Please send your showile to eos(dot)moderator(at)etcconnect(dot)com, thank you.
  • Thank you for your showfile.
    You're missing the range labels.
    If you want to show images you will have to create a gobo wheel and assign it to your channels. If it's enough to just show labels it's enough to label the ranges. But either way you need labels for your ranges.
    Just with labels:
    • Fixture Editor > Ranges of parameter Gobo_Select
    • Encoder Display
    With images:
    • Gobo Wheel
    • Encoder Display
    Does this help?
