Isolate, moving lights in submasters
we acquired four moving lights and have them permanently patched into our system. Unfortunately, now whenever we bring up a submaster of cyc lights or other washes the moving lights, return to home
How do we isolate the moving lights out of the other submasters?
  • Record in Eos is greedy. When you use the Record button without including something specific like a channel or parameter before the word Record, Eos will record everything for each channel that has at least one parameter not at its home value anymore.
    If you make sure to do a GoToCue Out before creating a look that you want to record to a sub, you will not have any leftovers and can use a simple Record.
    To clean up the subs that you already have:
    [Blind] [Sub] 1+2+5 [Enter] (use the numbers for your actual subs)
    Chan 11 Thru 14 [At] [Enter] (use your moving lights' channel numbers)
