Playing around in the Snapshot List I get an error if press the Softkey "Direct Selects".
Also the Softkey "Offset" make no sense for me.
EOS 3.2.9 and 3.2.10 MacOS Sequoia on M4 MacBook Pro 16''
The category softkeys need a snapshot selection in the command line.
Offset can be used in a record target context: Snapshot 1 Thru 5 Offset 2, which will select snapshots 1, 3 and 5. This offset syntax is available for other record targets as well, e.g. cues.
The selection in the command line is only needed for the Direct Select and Offset softkey, all other softkeys post automatically the actual selected snapshot(s) in the command line.
Ah, fair. I will look into {Direct Selects} not auto-inserting the selected snapshot.
Regarding Offset this is consistent behavior, e.g. with cues.
Offset should also post the snapshot if there are more than one snapshot is selected.
In general the handling of the snapshot soft keys are very confusing, because it works like a logical NOT.
e.g. "Snapshot 1 Fader" deselect all other attributes not the Fader attribute, I would expect that only the attribute which is selected will change the state.
Also in cell editing should work, simply by changing the attributes state by (double) clicking.
