is there any special setup with import of congo V6 file and EOS 1.9 ? cuelist is okay but cues are empty ?
I think, with 1.7 it worked, I don't know with 1.8 and not with 1.9
Hi Pilou,
something went bad when we moved to V1.8 and the asc import stopped working as it should.
We plan to have this fixed with the next software update.
A possible workaround is - doing the conversion in 1.7 and then installing in 1.9.
Hope that helps.
Pilou, you can also email me your showfile. We can do the conversion in a 1.9.5 build and then send it back to you. It'll work fine on 1.9.
a
