Element 1 bump button not working on non-dimmer channels
Hi there,
I ran into an issue where putting non-dimmer channels (channels that have more than just intensity, e.g. RGB par) on a sub with intensity full only. When I move the fader up, normal behavior happens: the lights slowly increase in intensity. But when I press the button underneath the sub, the intensity of the light doesn't go from home to 100%. I tried deleting the sub and creating it again, so default sub settings are used.
When I use a channel that is just a dimmer in path (only intensity), the bump button works as expected.
I don't necessarily need to bump intensity right now, but I would like to know if this is intended behavior, and maybe I'll need it in the future.
Thanks in advance,
Lucas
