Preferred insert workflow to avoid tracking mistakes
I'm wondering what is your best workflow you all when inserting new values for a channel already used earlier and later in a show.
For example: I have a light turning on in cue 1 in red and turning off in cue 2. In cue 5 it turns on again in red because tracking. If now I add cue 3 with the same light in green, it will make the light to turn on in green in cue 5 because of tracking from cue 3. Is there a way to avoid this easily when recording cue 3? Like an option 'if the light turns on again after this cue block the values before recording'.
I know I could check in blind the tracking life of the channel before recording but this sounds like a lot of work if working on a busy show.
My other option would be to voluntarily block the values when recording in every new scene or whatever but it doesn't sound ideal.
