Bug: Mark @ 0 does not work with multi-cell fixtures
When I have a Multi-cell channel at 0 with a Mark on it, the Query will either select the Channel Minus Cells, or not select the Channel at all depending on if the Master is Marking or if only the Cells are Marking. But before you hit Enter at the end of a Query, it already highlights all the channels in the Channels Table that the console is about to grab including the correct cells, but upon hitting Enter they are never selected. Therefore when I [At] [Enter] my queried selection, the Channel Master is returned to tracking, but the Cells retain their Mark and move instruction.
In addition to the Mark At 0 not working for Marking Cells, it will also remove Cell selections from other parts of the Query, so if I have a Multi-Cell fixture with Dark Move data in both the Master and the Cells, and no Marking in the Cue and I then type
{Query} {Dark Moves} {Or} [Mark] [At] [0] [Enter]
It will also only select the Master instead of the entire Channel. Using only {Query} {Dark Moves}, does select the entire Channel, so the Mark At 0 part is interfering with the entire selection not just the parts that are Marking at 0
v3.2.10.36
