(Bug?) Mark adding move instructions to unused parameters
Hi there,
I'm running into a weird oddity with manual mark. I'm touring a show where EVERYTHING is palletized and in presets so it is very easy to move from venue to venue. For this reason, I don't want ANY discrete data in my cue list. So everything that is not related to the show is left outside of the presets and not active (text in live table is grey), for example the color mix macros in certain fixtures. This works great because as the fixture is replaced in patch, it inherits the home values from the fixture profiles and plays nicely, if I have any problems, I update my home preset and it stays in the new values. The issue I'm running into is when I go to mark a fixture globally for example [201] [Mark] [Enter] [Update] [Enter] all the non active data that has been tracking through the whole show receives a move instruction and tracks through the rest of the cue list.
I'm sure this is a bug cause as you'll see in the video the iris gets a whole move to zero in a show that I don't even use it, It was frustrating trying to find the cause as the iris kept blacking out the fixture so I thought it was a fixture problem.
Attached is a video of the behaviour:
