Hey there!
Me and a friend are building an ETCNomad setup using a Behringer x touch compact as a midi/osc controller. The thing is that the x touch also has rotaries which I would like to use like the rotaries found on consoles like the ETC ion XE.
Would it be possible to make it so that if I select a channel, I can use the rotaries to edit (Only for the selected channel) parameters like pan, tilt, RGB and CMY?
I can't really find a good way to do this anywhere without making subs for every channel respectively which would kind of suck.
Sorry if this is a stupid question, thanks for your help anyways.
