Bug - Removing effects from cue parts does not affect the PSD
If I create a new part, and put an effect in that part, such that the effect is the only instruction in said part, the PSD timing will adjust from the "blank" formatting to the expected "in use" formatting.
If I then remove the effect from that part, making the part empty, however, the PSD timing still shows the part as containing move instructions.
