Color Picker control with a Elation Artiste Monet
Have a question about color control on a fixture that I may be getting.
I'm looking at the Elation Artiste Monet in ML Controls. This is a LED Spot fixture that has both CMY & RGB color flags. In ML Controls, when I pick a color on the Color picker, the CMY parameters get a level, but the RGB don't. Also, if I manually set a level on the RGB parameters, the color picker doesn't change.
I figured that those parameters weren't activated in the Color Configuration section in Patch, but when I look at that fixture in Patch, I don't see the Color Configuration button. How does what the picker control get set in this situation??
I also looked at the Elation Artiste Mondrian, which also has CMYRGB, and it acts the same way.
Any thoughts??
Jeff
  • There are different things in your post to talk about:
    • The color configuration in patch exclusively works for additive color mixing systems, which the Artiste Monet doesn't have, it's a subtractive system.
    • Eos currently doesn't understand the CMYRGB color mixing system and will only control the CMY flags.
    • We have written up [EOS-56366] to fix an issue you haven't encountered so far: In current versions of Eos you will see the color and intensity values incorrectly displayed in Augment3d and magic sheets. This will be fixed in a future version of the software.
