Hello,
I found a thread from 10 years ago mentioning that quick save only works the first time you open the editor. I am currently using software 3.2.10 b36 and this still seems to be the case. Is this still on the list of snags?
Katie
Hello,
Katie
In a quick test I'm not quite seeing that, but I see how it can look this way.
I'm seeing that clicking the Quick Save button will create and undo point each time you click, but each following undo point will remove the previous one. If you click it 5 times you can then return to the fifth undo point but not to the previous ones. The confusing bit is probably that you only see the green check mark the first time you click, even if the following times undo point are successfully created.
Do you agree this is what happens? Otherwise I'm happy to look into this a bit more.
I am, thank you. Any chance we could get the green tick every time we create a successful point? It is proving a little confusing for my trainees.
This is written up as:
[EOS-49937]
Magic Sheets: Quick Save won't show checkmark after first click
