I'm looking to run an effect where the lights turn off in groups of 3 via a sub. I built an absolute effect with 2 steps. The first at background and the second at 0. The effect runs 1 cycle and groups to 3 and the exit is "stop and hold". When I run the sub the lights turn off as expected but when I release the sub the levels of the effected light remains at zero. If I select of the effected light it shows that the current level of 0 is from the background cue, but in blind the cue still shows the light has intensity above.
I'm building this with a sub instead of a set of several cues because I'm on a film set and lots of changes happen at the last minute so I prefer to use subs for cueing. If I change the exit to anything else the sub acts as expected when released with the values restoring to the background cue. Unfortunately "Stop and Hold" is the only way I can get the lights to stay off till I release the sub.
I've tried just about every setting in sub properties and effect and can't seem to find a way to rest the lights by releasing the sub.
Is this a bug or the expected behavior ?
