Hello!
I am trying to set up a board in a venue where the people running it will do very little programming and just want the faders to do the things they've asked. This is on an etc element.
I have some Elation Sixbar 1000s, that I've saved as Red Green and Blue faders so they can mix and match, but when turning up the faders, they start as white and only get more saturated if you turn the faders up all the way. And then if I try to add say, some blue fader with the red fader up it will mix a little, but then overwrite once it's at 100 rather than turning purple. I'm wondering if there's a way to store intensity to go from 0 to 100 but for the color to be there from the beginning, so I can actually mix them.
