Hi! Seeing if this is expected behaviour. I've been editing a fixture profile to make it suit my needs a bit more. However, the parameters I've changed now won't display their labels in the live table, only the user number. Label still shows in the encoder display. The parameter is in snap so each frame is a new label.
Also, one parameter used to have a mode attached to it, which I removed, but there is still a mode option on its encoder display.
Is there any advice of how to get the label to display instead of the user value for each frame? The fixture profile works fine and behaves correctly on unmodified parameters, editing them seems to break this link.
