Just curious, can Eos iRFR work with any fixture or does the fixture have to be an EOS fixture?
Additionally, can the app work with the Jester24ml or is it only EOS based?
The iRFR App is a remote control for Eos Family consoles. As such it can control all fixtures that are patch and controllable from the console you're connecting to (i.e. not limited to ETC fixtures).
Would you mind guiding me through how to connect the app to a Jester24ml console? I have read through the instructions for EOS software but I am unsure how to connect it to Jester24ML which I believe has no software. Thanks so much.
Hi Lighting Lover,
The iRFR App can only be used with ETC Consoles. It will not work with Jester24ML.
Ah right ok thank you. I miss understood. Thanks so much
eos moderator or corey cascio If it is not too much trouble, could you please respond to this question? Best fixture for medium space
