Is it possible to run EOS on my laptop connected to wireless router so can use aRFU app?
Short answer, Yes. The right router type must selected von different vendors, depending on the room size you work and if you need one with a build in DHCP server. I'm using some cheap TP-Link routers.
Yes it works, BUT make sure you're only using the app, do not try to use Nomad in any sort of a multi-client/console configuration -- you will have problems. But using the app, you should be fine.
