Changing a cue link doesn't change the pending cue
When playing back a cue, I can give that cue a link and it will change the pending cue to the linked cue. But when I change the link to something else, it doesn't change the pending cue. When I hit Go, it plays back the first cue I linked to instead of the new linked cue.
3.2.11
  • I also have noticed this and reported it... That is the correct and currently the intended behavior -- when you enter into a cue the playback system already understands the next cue that it is going into, so GO will always go there, regardless if you chance the link after you enter into this.
    However, this is not dissimilar to when you make a chance to a cue in blind, if you make changes to the current cue while in blind it does not update it until you [go to cue] [Enter]
    That same process will also take care of your updated link --  so once your in the cue with a link, if you update the link target, just [go to cue][enter]  and the pending cue will now be the new target.
