Software: Eos v3.2.12 Build 1
Prerequisite: User configured with Intensity CueOnly enabled in Setup > User Settings > Record Defaults > Update Defaults
When updating the non-active cue, the Intensity CueOnly modifier is ignored and intensity values are updated with tracking.
For example, with cue 7 active, adjust the intensity value of a channel or channels.
[Update] [Cue] [5] [Enter]
The new intensity value/s will track forward from Cue 5 ignoring the Intensity CueOnly modifier that is enabled for the user.
This issue occurs both when updating to an earlier or later cue than the active cue.
This behaviour seems incorrect and in direct contradiction to the purpose of the update modifier.
The current work-around is to add the CueOnly modifier to the update command: [Update] [Cue] [X] [CueOnly] [Enter]
