Unable to control Moving Lights with XYZ only Pan / Tilt function works.
Looking for some help.
Adding some acquired used movers (Clay Paky Mythos2) we had 6 CPM2 already and were adding 8 more to the inventory. I have them patched in. The problem is the new channels are not allowing Movement via XYZ only allows Pan / Tilt. The 6 original channels allow to control movement both XYZ & Pan/Tilt.  It's not the fixtures as some of new fixtures are on the old channels & both XYZ & Pan/Tilt work for them. So I'm missing something in the setting for the new channels. I see the XYZ Disable/Enable function in the ML Controls but its not having any effect to address the issue. It like they are locked in to Pan/Tilt & not allowing to control via XYZ even though the XYZ values change on the screen when using the XYZ controls the fixtures do not response.
