Hi everyone,
I've got a modestly annoying OEM LED system installed in the walls of my theatre. It's a system comprised of 134 panels each with an individually addressed RGB LED strip mounted behind it.
I use a lot of student labor for events - so I often set up our Ion with a handful of submasters - house lights, stage wash, video look etc. I often build two or three color sets for the walls.
I recently updated to 1.9 and I'm running into a problem. I bring up the intensity of the walls, adjust the color to what I like, hit record and the bump button on the sub I want to record - just like I have for the two years I've had the desk. I usually change the wall sub into an intensity sub so that I don't get a color shift at lower intensities.
When I bring that sub up everything looks fine. The walls come up - the color is right, everything's like I want. About 2 minutes later the walls fade to black. The channel info tab still shows intensity as full.
I repeated this by recording the walls into a cue. Same result. I ran the cue - and after sitting for a few minutes the intensity faded out.
Any ideas?
-Bryce Larson
Production Manager
The Arts Center on 7
