Version: 3.3.0 build 549
There is unexpected behavior when using offset when "removing" / minus channels.
This shows up in the visual indiciator of fixtures in most cases, and in many cases can also impact how offset is applied to channel selection.
Example:
Group 1: channels 1 thru 5
CLI: Group 1 - 3 Offset
Shows:
Mirror in shows the wrong visual:
However setting @ 20 thru 80 produces the expected output
Example 2:
CLI: Group 1 + 6 - 3
Produces:
Adding Per Group 2
It looks like it just might be a case of it incorrectly detecting the correct number of fixture objects to show.
I thought there might have been a situation where this problem impacts actual channel selection, but I've been unable to reproduce it. So it might simply be cosmetic.
