Hi everyone,
I’ve been working with the Aladdin lamp system using EOS and Nomad System and I’ve run into a couple of issues I’d love some input on.
Temperature Adjustment Affects Intensity
 When I set the lamp temperature to 80, I notice that some lamps limit their intensity to 80 as well. I confirmed this by checking the remote control, which also shows 80.
 Interestingly, when I lower the temperature to 0, the lighting becomes noticeably brighter, and the remote shows 100.
 However, if I increase the temperature to 100, some lamps black out completely.
 I’m not sure if this is expected behavior or a system limitation.
Flashing Lamp Issue
 I have one Aladdin lamp that keeps flashing, but only when I use it alongside other lamps.
 To avoid disruption, I’ve had to unplug it for now.
 I’ve already tried:- Swapping the lamp with a working one
- Changing the remote control
 But the issue still persists.
I appreciate any advice or suggestions you might have—even if they don’t directly solve the problem, they might help me understand it better. Thanks in advance!
