Should OSC Commands in English Work with Console set to German?
Most of them seem to work, so it must be at least mostly decoupled, but there's like a couple commands that seem to not work. Do I need to fix this on my end or is that supposed to be done fully by Eos? I can try to figure out exactly which commands, if needed, but I'm just wondering if it's like, "Yes, that's supposed to be completely decoupled", or "No, you're lucky it works at all".
  • So it does not like "Event", but in Spanish mode it does like "Evento", and it does like "Show_Control_Action" in English mode but not "Mostrar_acción_de_control" which is the closest translation I have for Spanish.
    But it has zero problem with any of this in English mode. So it seems isolated to show control?
    OSC: -Address: /eos/user/1/newcmd -Argument: Record Snapshot 1 Enter Enter
    OSC: -Address: /eos/user/1/key/live -Argument: 1
    OSC: -Address: /eos/user/1/key/live -Argument: 0
    OSC: -Address: /eos/user/1/key/macro -Argument: 1
    OSC: -Address: /eos/user/1/key/macro -Argument: 0
    OSC: -Address: /eos/user/1/newcmd -Argument: Delete Macro 88888 Enter Enter
    OSC: -Address: /eos/user/1/newcmd -Argument: 88888 Enter
    OSC: -Address: /eos/user/1/softkey/6 -Argument: 1
    OSC: -Address: /eos/user/1/softkey/6 -Argument: 0
    OSC: -Address: /eos/user/1/key/event -Argument: 1
    OSC: -Address: /eos/user/1/key/event -Argument: 0
    OSC: -Address: /eos/user/1/key/8 -Argument: 1
    OSC: -Address: /eos/user/1/key/8 -Argument: 0
    OSC: -Address: /eos/user/1/key/\ -Argument: 1
    OSC: -Address: /eos/user/1/key/\ -Argument: 0
    OSC: -Address: /eos/user/1/key/internal -Argument: 1
    OSC: -Address: /eos/user/1/key/internal -Argument: 0
    OSC: -Address: /eos/user/1/key/time -Argument: 1
    OSC: -Address: /eos/user/1/key/time -Argument: 0
    OSC: -Address: /eos/user/1/key/enter -Argument: 1
    OSC: -Address: /eos/user/1/key/enter -Argument: 0
    OSC: -Address: /eos/user/1/key/enable -Argument: 1
    OSC: -Address: /eos/user/1/key/enable -Argument: 0
    OSC: -Address: /eos/user/1/key/select -Argument: 1
    OSC: -Address: /eos/user/1/key/select -Argument: 0
    OSC: -Address: /eos/user/1/softkey/3 -Argument: 1
    OSC: -Address: /eos/user/1/softkey/3 -Argument: 0
    OSC: -Address: /eos/user/1/newcmd -Argument: Delete Macro 88889 Enter Enter
    OSC: -Address: /eos/user/1/newcmd -Argument: 88889 Enter
    OSC: -Address: /eos/user/1/key/disable -Argument: 1
    OSC: -Address: /eos/user/1/key/disable -Argument: 0
    OSC: -Address: /eos/user/1/newcmd -Argument: Delete Event 888 / Enter Enter
    OSC: -Address: /eos/user/1/newcmd -Argument: Event 888 / 1 Thru 199 Enter
    OSC: -Address: /eos/user/1/newcmd -Argument: Event 888 / Frame_Rate 24 Enter
  • My other reply got filtered as spam because I included some log output, but I identified "Event" and "Show_Control_Action" as the offending key words, but oddly, "Event" worked just fine in a different context. Seems to be the same problem in both German and Spanish mode. And like a billion other commands worked just fine before the offending ones. And "Evento" corrects part of the issue with it set to Spanish.
  • I'm going to close this out on my end as an Eos bug. Someone probably keyed something by display_label instead of the static id_name. display_label is dynamic and adjusted by language settings, but the logic should always point to a static id_name. Which is seemingly done correctly in most places, but not all places. It's not practical for me to fix this on my end.
