I have a touchX mini midi board that I can connect to my laptop via usb. I have my laptop in ETCNomad Element client mode and the main console is an Element 60. Both are running 3.3.0. In Luminosus, I can use the ip of the Element console and it works, but using the ip of the client doesn't work, even though the midi panel is literally plugged into the client, which is my laptop.
I think the update lag would be reduced if Luminosus would communicate with the laptop, as it would be a local communication thing, instead of going over the network via ethernet and such to communicate with the (older hardware) Element console.
Am I not doing it right, or is it just not possible to use Luminosus with a client? And when I run ETCNomad offline at home, so without a console, Luminosus works fine locally.
