ETC radio RFR flexi
For forever I've been using the old school radio RFR hand held device and occasionally an iRFR phone app for channel checks. After a scheduled maintenance power outage both RFRs started going through individual cells in mt ColorForce 2 strip lights. I usually do a simple channel check, just hitting next next next. Last week when doing so it would go through the Main channels only and light up the whole strip and then move to the next strip. Now it does main channel, then goes through cells. I am on 3.3.0 right now and have been for about a month now. Other than the power cycle nothing has changed. I set my primary and backup consoles to be flexi to cells off. Then power cycled the RPU again. This put my iRFR into how it used to be, just main channels, no cells. I run my iRFR in user 0. The old radio RFR is still stuck in going through cells. Diagnostics tab tells me old RFR is user 301, which is not a user I can set the console to. I do not really understand what happened and how can I flexi the old RFR to be cells off? It obviously only goes through patched channels so it has some sort of native flexi?
