[Bug] Changing Macro Colors
Hi, I'm having a seemingly impossible bug setting macro colors from within macros. I have 2 identical macros (1 & 2) where one fails due to a does not exist error and the other works just fine. So far, I've noted that you can move the macros to any number and the same one keeps failing, and the target macro for the color change can be any 3 digit number. Changing the target to 2 digits causes both macros to work again. I assume there is something wrong with macro 2, but they're identical (or at least they're identical in the UI)
Macro Color Bug 2025-10-20 20-04-48.esf2
