Sneak Channel levels bump to full
When I use a submaster to control a channel, then I change the levels in Live mode for my show. After that, I sneak the channel back to submaster’s levels, but the levels bump to full.
My version is 3.3.3.10, here is my video,
Thanks a lot.
  • Sneak fades to the backround state, that was active at the time the sneak-command was entered.
    If the backround state changed since then, sneak will fade to the (now obsolete) background state, and will then snap to the current background-values.
    This may happens, for example, when a Sub is touched, while a Channel, that is stored within this Sub sneaks.
    This has been an issue for quite some time. I posted about this issue in the 3.2.x beta forum but never got an answer.
