While programming cues I was having an issue with some lights. I soon realized in the top left corner of my display screen it no longer said manual it said tracking. How would I change it back to where it says manual
You can have manual values both in Tracking and Cue Only mode. The red text Manual is added after either mode.
To change from tracking to cue only go to Setup > User and in the Record Defaults you'll see the Tracking seeing that you just have to click once.
Just a short explenation on top:
If you see the "Manual Values" in the top left Corner, that means you have non-recorded Values on stage.
If the "Manual Values" is no longer there, all your values on stage are only from recorded sources.
