This has been an issue for a few versions now, just flagging it as an ongoing issue:
Block sometimes won’t block all of the parameters of a light.
This is usually in a part cue where you’re trying to block a light completely’in blind. Some parameters just won’t. If you manually set them to the same preset they’re already in then they will turn white and be blocked, but the block button won’t do it.
it’s as if it thinks some parts of the fixture are blocked, compressing the block button is trying to unblock them. I’ve speculated in the past about whether this might be caused by ‘hidden’ parameters that some parts of the code can see but others (and us humans) can’t.
more confusingly, it’s inconsistent, since sometimes it works just fine I can’t pin down a pattern, though.
Whatever the cause, t’s really frustrating…..
