Evenly distributing Pan/Tilt between two Focus Palettes (Fan across fixtures?)
Hi!
I’m wondering if Eos can automatically evenly distribute Pan/Tilt across a range of moving heads between two fixed positions.
Example setup:
  • Fixture 1 should light the far left side of the stage (saved as Focus Palette 1)
  • Fixture 6 should light the far right side of the stage (saved as Focus Palette 2)
  • Fixtures 2–5 should be spread evenly between those two positions.
Since I can’t test this at the moment, I’m trying to understand whether Eos can do something like this:
Chan 1 Thru 6 Focus Palette 1 + 2
In other words:
Does Eos have a way to fan or interpolate Pan/Tilt automatically between two focus palettes, so the fixtures in the middle land at evenly spaced positions?
Or is manual use of the Fan encoder function the correct/only approach?
Any guidance or workflow suggestions would be greatly appreciated!
Thanks in advance.
  • Yes this can be done. You can Fan palettes with [Chan 1 thru 6 Focus Palette 1 thru 2]
    Theres a catch though. When you only record your starting position (Chan 1/FP1) and your ending position (Chan 6/FP2) you're not able to fan Chan 2 thru 5 over those palettes, because these palettes are discrete and do not contain any values for Chans 2 thru 5. You can mitigate this by making FP 1+2 a by-type palette (which stores the same values for same fixture types in the show). then the Focus Palette 1 thru 2 syntax should work like expected.
    buuuut....... Fan is gonna be faster most of the time i'd say :D
  • If you use A3D you could Fan from L -> R refenrencing your X-Focus:
    1 [Thru] 6 {X Focus} -5 [Thru] 5 [Enter]
    Any kind of fanning would be my choise to do it as well.
  • Something to add on to this. You explicitly asked how to fan palettes so i didn't mention it. You can obviously fan pan and tilt values across your selection with syntax and the CIA if you're trying to do basic fan in/fan out/x-over looks with specific angles.
    [Chan 1 thru 6 Tilt -45 Pan -45 thru 45 Enter] will get you a basic Fan out look in a pinch.
    This style of Fanning should work with every parameter in Eos and is really powerful in combination with Offset.
