Send multiple OSC strings with one cue
Currently Cue 1 > Execute > String either makes a new string or starts editing the existing string. But I see a table full of empty cells underneath the top cell which contains the osc string. So can I send multiple OSC strings when activating one cue?
Basically an easier way to achieve the same thing as making a second cue which is empty but contains the second osc string and then using a Follow 0 from the first cue (containing the first osc string) to this second empty cue.
  • In the execute section, you can add multiple Cues/Macros/Snapshots/Relays to trigger. However, from my testing it seems like you can only add one String and one MIDI Data Sting which is a bummer.
    You can put multiple strings into a single macro (there's a Send String command) to be executed or you can group your strings in macros and add multiple macros to the execute to get some more modularity. Doing it this way keeps keeps your Cuelist clean while bloating your Macro list a bit which is a good tradeoff imo.
