V3.2.3 and also 3.3.4 if I run a submaster with some intensity value inside. then select some channels to make them manual i can't update the q untile I put the sub to zero. Is it a expected behavior?
EX
Go to cue 5. Channels from 1 to 10 are at 0.
Run Sub 1 ---> channels from 1t 10 go at 100 in Yellow
channel 1 make manual (value change to red)
Update is impossible
