Hi.
I'm doing referenced marks for our latest production, but I'm getting some unexpected update behavior.
When a Channel is currently marking but we decide to use it in that Cue, i turn it on, adjust values, make presets and update that change into the Cue. Since i'm using the desk in Cue only mode, after updating, i'm used to blind into the next Cue and clean up Livemoves. However, when a Referenced Mark channel is updated into a Cue with values, all NIPs are tracked throughout the mark range (like a Update Track Intensity CueOnly)
Is this expected behavior? I can manually override this update behavior with Update CueOnly (even though im in Cue Only mode by default)
Thanks.
