RDM
Hi, If I have a show file with RDM active and someone changes the address and mode of a fixture either manually or via another show file, when I re-open my show file will the fixture(s) be repatched automatically?
  • Changing fixture profiles in patch affects all stored show data for those channels so I would be shocked if it automatically repatches your whole show based on rdm data.
    if you have a show file with your current patch you can do a advanced merge and merge just the patch in your other show file. make sure to backup your old show file because once you merge the new fixture profiles show data will change.
