Howdy!
We've run into an issue with Marking, that we haven't been able to reproduce.
In a tightly cued sequence, where we have a quick dump out of effects into a restore, we added an auto follow to re-mark the lights for the cue directly after. The lights were at 0.1 doing an effect in the main cue, and then went to 0 to quickly remark in the 0.1 auto follow.
When running the cue, the lights would not end up in the correct place (almost as if they were receiving an override from an effect or being focused to the wrong spot).
If you used Go To Cue, the lights would end up in the correct spot, but then when you stepped back to run the sequence, the lights would continue to be in the wrong spot.
The only way to fix this was by going to cue out, and then going to where we were in the sequence, and everything ran fine/without issue, but to prevent further problems, we live move the fixture in dark to its correct position and then have it fade up in the next cue.
This sounds very similar to the bug that RobHalliday reported - https://community.etcconnect.com/control_consoles/eos-family-consoles/f/eos-family/61736/the-return-of-effects-that-never-die
Thank you!
