I just updated to 3.3.4Build21. Two consoles are locked Gio (DisplayPort) no EEPs. I have 4096 usable parameters/addresses, and this is confirmed in the CIA.
In Setup > system settings > Processors, it reads outputs added 4k (makes sense, from primary console as host) but then reads 1936/8k params. And 11/16 universes.
Shouldn't the parameter cap read 4k? I patched a bunch of dummy channels with large footprint fixtures to inflate my numbers as a test. The universe count doesnt stop me past 16 and I get a Max Address limit error past 4096, which is both expected behavior. Seems strange the tab would claim I have 8k params when I definitly do not. I assume the 16 universe number was populated from the 8k addresses, even tho universe count is not the limiting factor
For more infomation, when my universe count went above 16, it read 17/16. Then when my parameter count went above 4096, I now read 5036/8k, and BOTH the param column and universe column numbers turned yellow. Not seeing in the manual what a yellow number means, i assume error, but may just have missed it
