Setting Cue Execute with macro
Hi all, Am currently playing OSC as research for a future project, does anyone know if you can set cue Execute parameters using a macro?
My current macro is as follows:
```Execute Send_String /example/output/cue=%1```
It's entirely possible my macro syntax is wrong, but right now it simply does nothing when I run that command.
  • This doesn't work for multiple reasons:
    1. Send_String is the wrong command. It's used when you want to send OSC directly from the macro. You need String.
    2. The per-cue executes don't have access to the variables like %1 representing the cue number.
    It looks like you want a cue to send an OSC command with that cue's cue number. Why not use either Setup > System > ShowControl > OSC > OSC Cue Send String, or the cuielist's OSC Cue Send String property?
  • Thanks for your quick response!
    I will take a look at using String instead of Send_String, that looks like it will fix the issue.
    The reason I wanted to use the argument to send the cue number was to avoid having to sift through all the cues in the other programme. For example triggering a standby command on certain cues, rather than having list of cues where there will be a standby, and comparing every time there is a cue update. I could look into having a dedicated cue list for the stuff, then trigger those cues which then trigger OSC, but that would become more friction for a programmer.
    What can probably do is use a macro to create each executor, and put the cue number in the command there, rather than trying to use the %1 variable.
