Labelling Groups - bug? | v3.3.5 b69
Just updated to 3.3.5
When labelling groups in Live, I have found a weird behaviour where it wants to label the current active cue instead.
With a group recorded, typing:
Group xxx Enter || Label
This then behaves as if I was pressing label on an empty command line and labelling the current active cue.
  • Thank you for reaching out. However this isn't new behavior. It's a side effect of a group representing a channel selection. As soon as you press Enter after the group number, the group becomes a channel selection. And since channels can't be labelled outside of patch, pressing Label then looks for an object to label and finds the Cue.
    I quickly looked into older versions of the Eos software and found this behavior going back at least 6 years. If you feel it's important to change, please head over to the Feature Request section and add this idea there.
