Using 3.3.5 if you create an element in a magic sheet and then send an OSC command, the text label of the element changes to 1.000 the first time it's clicked and then reverts between 1.000/0.000 (reflecting the button status) when clicked, losing the original text label entirely.
Renaming the element to the same label as it had initially fixes it and the behaviour doesn't repeat.
See attached
