TouchOSC (new version) → EOS OSC: how to send simple /eos/cmd text commands?
Hello,
I’m trying to set up a very simple OSC workflow between TouchOSC (new / Mk2 version) and EOS Nomad, and I’m running into what seems to be an interface or documentation mismatch.
Context
  • EOS Nomad on macOS
  • TouchOSC new version (not the legacy TouchOSC + Editor)
  • OSC RX is enabled in EOS
  • UDP RX port is set to 8000
  • TouchOSC is correctly sending to that IP/port
  • I can confirm network communication is working
Goal (very simple use case)
This is not for show use, only for focusing from the stage.
I want a TouchOSC button to send plain EOS command-line text, for example:
  • Chan 1 Enter
  • @ Full
  • @ 0
  • Clear Clear
In other words, the equivalent of typing text into the EOS command line via:
/eos/cmd  "Chan 1 Enter"
Where it breaks
In the new TouchOSC UI:
  • I can set the OSC Address to /eos/cmd
  • However, I cannot find a reliable way to enter a free text string argument
  • The “Arguments +” menu only exposes control properties (Color, Name, Tag, etc.), not a literal string
  • The “Value” field shown in the OSC message panel is not editable
  • This makes it unclear how to send raw command-line text to EOS without scripting
Question
What is the correct and supported way in the current TouchOSC version to send a plain text OSC command to EOS?
Specifically:
  • Is there a proper way to send a string argument to /eos/cmd without using Lua scripting?
  • Or is scripting now the expected/recommended method for this use case?
Any clarification or example would be greatly appreciated.
Thank you very much — and thanks for continuing to make EOS such a solid platform.
www.dropbox.com/.../Capture-d-cran-le-2026-02-12-19.03.31.png
Best regards,
Pascal
