Copying a cuelist and associated time code events to another cuelist.
Hello there,
I usually find all the answers i'm looking for in other discussions but this time i must admit that I'm lost.
I'm currently at the end of the design of a dance show which includes two different parts with different dancers. So i've been using different cuelists to keep my head (and my show) clean. I'm currently working on an Apex10.
Unfortunately, in less than two weeks, the venue that will be hosting the show only has an Element2.
So I've been doing some thinking about putting the two shows into one sole cuelist. Problem is that every cuelist has it's own time code.
I already moved the cues from my second cuelist to cues 201+ and I copied the cues from CL1 and CL2 to a cuelist 3. I also managed to copy all the timecode events to a new event list (adding +1:00:00:00 to all the events from my CL2 to keep the timings and only adding a SMPTE track that starts at 1:00:00:00 for the second part of the show).
Now I'm stuck at the part where I need to change all the actions cue1/1thru and cue2/1thru to cue3/.
When I type in my event list 3/ :
3/1Thru Enter Cue 3/ Enter
Every action is now Cue3/1.
Is there a way around this or am I destined to split the 2 shows into 2 different files and open them after one another on the Element2 ?
Thanks in advance for your insight  !
